964 911-C2 engine stalls due to low mass flywheel
Old Jul 22, 2005 | 01:27 AM
zoom_928's Avatar
Default 964 911-C2 engine stalls due to low mass flywheel
I have a 1992 964 911-C2, 3.6L with a lightweight clutch and low-mass flywheel. Whenever I am driving with the A/C operating, if I disengage the clutch and simply let the engine speed drop on its own, the car will often (50% of the time) stall. It would appear that with the reduced mass of the flywheel, the engine doesn't have enough momentum to give the ignition system time to catch the motor before it dies. It seldom, if ever, does this if the A/C is not operating. Does anyone have any suggestions on how I can keep my flywheel and still enjoy the benefits of air-conditioning?
Old Jul 22, 2005 | 04:14 AM
MBS Auto Parts's Avatar
Default RE: 964 911-C2 engine stalls due to low mass flywheel
I think the only sollution is to go with a new fly wheel..... sorry
Old Jul 28, 2005 | 02:13 AM
PorschePhD's Avatar
Actually this can be fixed with a proper program. The issue is the ISV can not move fast enough based on the 8X8 grid in the dme. A properly tuned ECU chip will correct the issue. You can also adjust the ISV to help however this is more a band-aide then fix.
Old Jul 30, 2005 | 09:26 PM
zoom_928's Avatar
Thanks for the response. I have an AutoThority chip for the car which I had replaced with the original stock chip. I had thought maybe the stock chip would not experience the same symptoms.
I think I'll put the custom chip back in and investigate tweaking the ISV to see if that will do the trick. If not, perhaps AutoThority can modify the programming on the chip to compensate for the LM flywheel mod.
Old Jul 31, 2005 | 01:35 PM
PorschePhD's Avatar
Yes, they can retune them. We do our own so we do not work with them directly anymore. I do know from past years they have the L/W flywheel fix.
jprsa
Jun 6, 2008 07:39 AM
tjmisch
Jan 15, 2008 04:20 AM
dave1986944
Oct 16, 2007 07:46 AM
rpmirage
Oct 8, 2007 08:15 AM
911rookie
Aug 18, 2007 09:27 PM
