Gap in instrument cluster, please help!
Old Feb 7, 2007 | 03:31 AM
911fiend's Avatar
Default Gap in instrument cluster, please help!
I just picked up a 2001 996, and I noticed an unsually large gap between the instrument cluster and the dash. As anyone seen this before who might know how to fix it?
[IMG]local://upfiles/3106/EF2E967715824D4A884842466554B8DB.jpg[/IMG]
Old Feb 7, 2007 | 11:02 AM
Default RE: Gap in instrument cluster, please help!
Some gap may be normal, I can't tell based on your picture and angle of the picture. If it is up a little, then it probably isn't snapped down all the way. You need to remove the torx screw from behind the hazzard button (pull off the trim piece with a small screwdriver), then push it down until it snaps into place and retighten the screw.
I take it there are aftermarket color gauge faces or carbon fiber trim around the gauges? It has to have been removed at some point.
Old Feb 7, 2007 | 03:10 PM
911fiend's Avatar
Yes, it's got aftermarket gagues so it was definetely removed. I tried snapping it back down without removing the torx screw but that didn't work. So I'll remove it and try again. Thanks PorscheDoc!
saline
Nov 7, 2011 07:08 PM
gvcirineo
Mar 31, 2007 11:57 PM
ducati4882
Mar 16, 2007 07:18 PM
ducati4882
Mar 2, 2007 10:34 AM
ducati4882
Feb 28, 2007 12:00 AM
