Hard to start when hot
Old Dec 5, 2007 | 07:53 AM
JayzTarga's Avatar
Default Hard to start when hot
Have a 79 Targa - 85k miles - seems very hard to start once driven and then sets for about 30 minutes. Car in great shape overall 8.5-9 - but this mystery plagues me. Remove air filter cover and expose metal plunger pump at fuel distribution area - once car is turned on and fuel reaches I manually pump a few times and engine will fire. Cold firing / starting usually not an issue. Anyone have any ideas?
Jay
Old Dec 5, 2007 | 08:08 AM
Default RE: Hard to start when hot
Might want to check your fuel accumulator and your fuel pump check valve. Both will cause similar issues.
Old Dec 6, 2007 | 06:45 AM
JayzTarga's Avatar
Doc,
Thank you, somone else on the West Coast mentioned the fuel pump check valve as well. Any ideas on repair / replacment costs for either / both? Have a good service company locally (Dave White - you may know them) that can service.
J
Old Dec 6, 2007 | 11:15 AM
The accumulator isn't cheap (around $150 IIRC), but the check valve is. Probably want to do a fuel filter at the same time since you are right there. I would imagine it will be a couple hours of labor.
active123
Jun 10, 2021 04:45 AM
jimporsche86
Jun 14, 2011 09:59 AM
OnesickCarreraGT
May 29, 2008 02:06 PM
84944s
Mar 16, 2008 02:27 PM
Mattrf
Oct 15, 2004 08:39 PM
