Oil burning question
Old Aug 12, 2005 | 07:05 PM
  #11
ECT's Avatar
ECT
Default RE: Oil burning question
Well, sounds like a Rear Main Seal (RMS) problem.
Take your car back to the garage.
More info? => Google- type in: "RMS problem 996".
An oilleak problem due to improper sealing.
Old Aug 12, 2005 | 07:10 PM
  #12
ECT's Avatar
ECT
A picture of the RMS:
[IMG]local://upfiles/1433/0ADFBBAD9D454CE49C9177C83BFAC55B.jpg[/IMG]
[IMG]local://upfiles/1433/28DCC7D07747492DB5AFE78B277DD593.jpg[/IMG]
Old Aug 14, 2005 | 01:09 AM
  #13
ebaker's Avatar
1 quart in 4000 miles is no problem. Most use a lot more than that.
Old Aug 14, 2005 | 07:25 AM
  #14
ECT's Avatar
ECT
Low oil level + blue smoke form your exhaustion pipes = burned oil.
Low oil level + non smoking pipes = oil leakage. A more serious problem. It can damage your engine irreversible.
Old Mar 26, 2006 | 04:28 PM
  #15
marlinspike's Avatar
If it's leaking that's one thing, but if it's consuming 1/4 quart every 1000 miles are you guys who are saying to take it back kidding? I know I'm a new member here, but I've been working on cars since I was 12 and I also read a lot about them. Industry standard level of acceptable oil consumption is 1 quart every 1000 miles. That's not Porsche, that's industry.
Old Mar 27, 2006 | 12:42 AM
  #16
pioneer's Avatar
Oil consumption for 911s are normal. Mine uses about 1/2 quart every 1-2000 miles. Some even say thats low for these cars. Not to worry dude... The dealership will tell you the same thing. Hope that helps.
Old Mar 27, 2006 | 01:35 AM
  #17
crimson96's Avatar
I agree, fairly normal. I have a 996TT, and of course you will always have some oil from the turbo bearing leak into the exhaust, so the TT use about a half a quart every 1000 give or take some. But even non-turbo will use some. Especially if you have done a lot of 'city' (stop start) driving - the oil level will, at first, actually rise, then after a good long run at freeway speeds will drop back down. So if you measured after a lot of city driving then did a measure right after a highway drive, you will notice a drop - thats with any car.
But I'd ask the dealer anyway...
ninefofo
Jul 25, 2008 06:41 PM
mechcyber
Sep 28, 2007 01:01 PM
bmwpeter82
Sep 14, 2007 10:17 PM
jeff_rx7
Mar 25, 2007 10:44 PM
paulz
Sep 23, 2006 06:26 PM
