oil failure warning - 03, 911 coupe
Old Aug 14, 2007 | 11:09 AM
asifallasleep's Avatar
Default oil failure warning - 03, 911 coupe
anyone ever get the oil failure warning? it has happened twice in the past two months. i've checked the oil levels each time and it's fine. the car performs as always. it happened again yesterday and the oil pressure gauge went to 0. i pulled over, checked the oil level which was fine and then restarted the car and everything was back to normal.
Old Aug 14, 2007 | 11:51 AM
Default RE: oil failure warning - 03, 911 coupe
The oil pressure gauge does not have anything to do with your oil level. 0 oil pressure on the gauge is catastrophic if the reading is true. Is the engine making any abnormal noises when this happens? Hopefully it is just a bad connection at the sensor, or the sensor itself.
Old Aug 14, 2007 | 12:35 PM
The engine performed as usual. I was on the highway when it occured and there was no change in performace at all. Someone else on another forum mentioned he had the same issue and that he changed the MAF sensor and that sorted the problem out. Not sure if i should start changing parts in hopes of figuring out what the issue is.
Old Aug 14, 2007 | 12:38 PM
Unfortunetly the Maf sensor is in no way tied to the oil pressure sendor.
Old Aug 14, 2007 | 12:58 PM
Is checking the oil pressure sensor something i can do? is it esy to get access to? thanks for your help!!
sotek
May 28, 2008 06:58 AM
porscheR1
Apr 5, 2007 11:25 AM
eneale
Nov 19, 2006 01:07 PM
TurboPropRob
May 2, 2005 08:21 PM
