Trans oil question
Old Feb 27, 2008 | 03:08 AM
28DOC's Avatar
Default Trans oil question
Hi guys, I have an '80 911 SC with a sticky 4th gear. They are all a bit tight but 4th is the worst. Have been told a quality synth oil would help. Any brands and weights would be appreciated. Cheers from Aussie-land.
Old Feb 27, 2008 | 07:34 AM
Default RE: Trans oil question
Typically I use redline 75w-90, but a lot of guys use swepco.
Old Feb 27, 2008 | 11:26 PM
28DOC's Avatar
Thanks Doc!
Old Feb 27, 2008 | 11:36 PM
28DOC's Avatar
While I've got you Doc, I was going to try 20w 50 Mobil 1 next oil change but a tech from Mobil didn't recommend it. He said that it would more than likely make it burn oil becuase of the age and klms (200k or about 120k miles) and the detergents in the oil. What's your thoughts?
Cheers mate.
Old Feb 28, 2008 | 08:36 AM
20w-50 is the standard oil you need to run in your car. Typically I don't run a synthetic in the older cars, because there is absoultely no need for it. The tolerances were not nearly as tight as they are today, and the engine has probably run standard oil in it for it's whole life, you will gain absolutely nothing by switching to a synthetic, and possibly will pick up some oil leaks if your old oil seals are starting to become hard. On the newer stuff that uses 20-50 (993's, etc), I usually use 15-50 when using a synthetic.
Keep in mind, Mobil 1 has changed their formula, and the oil contains less ZDDP's, which are additives which are shown to reduce engine wear. This has caused a huge uproar, and many people are switching away from M1 now. I have been using redline oil more and more, as those still have the additives, and there are other synthetics out there that still have the additives.
Old Feb 11, 2015 | 10:46 AM
Freddy Lewis's Avatar
Hey PorscheDoc,
New member here with a question please. I recently picked up a 1997 Boxster with 72,000 miles. I have small oil leak and covers the rear bumper slightly when pushed a little. The car set up 3 years before I purchased it. Is a 97 considered "old" ? I purchased Mobil 1 Fully Synthetic oil to do my first oil change. If the leak is valve covers or rear main seal, would an additive to help be advised, or forbidden? I thought of adding something like Blue Devil for a short period before changing the oil to see if it would help with the leak, before taking to mechanic to make any repairs. Appreciate your help.
Fred
Carl Fausett
Jul 9, 2015 01:01 PM
dm84944
Mar 22, 2009 10:18 PM
Speeddreemin
Feb 21, 2008 07:56 AM
944 nutz
Jan 4, 2006 09:42 PM
cdlaser54
Aug 8, 2005 09:21 PM
