Porsche 912 The Porsche 912 was a sports car manufactured between 1965 and 1969 as Porsche's entry-level model.
66 912 starter problem
Old Aug 31, 2007 | 10:18 PM
psykotik8's Avatar
Default 66 912 starter problem
today the starter on my 66 912 went out on me. its completely burnt out it doesnot even click. i have checked for voltage issues all over the car but everything checks out. i have two questions.
1) where is the best place to get a new/reman starter selanoid
2) where in the hell is it???
thanx
herbd
Old Sep 2, 2007 | 12:11 PM
sjenk24310's Avatar
Default RE: 66 912 starter problem
Hello herbd, The starter is located on top of the starter motor. It can be removed,
but first I would check the connecting cable and clean it to the solenoid
from the starter motor. You will also want to check and clean the hot wire
from the battery. Are you sure your key switch is not worn out and not
making contact? When the battery is low you will also get the same symptom
you described. The starter motor brushes can also be adjusted, but requires
removal of the starter and disassembly of it. There is a place in Hayward
Ca. called Parts heaven which specializes exclusively in Porsche and they
have everything, including the vintage stuff. Partsheaven.com, they will
ship UPS. Hope this helps you out; GOOD LUCK!
Old Sep 2, 2007 | 12:12 PM
sjenk24310's Avatar
Hello herbd, The solenoid is located on top of the motor. It can be removed,
Joseph Tainter
Jul 9, 2013 11:30 AM
kmpope
Mar 1, 2008 12:22 AM
apratkins
Mar 1, 2006 10:50 AM
foz
Jan 6, 2006 05:02 PM
jkaicher
Jan 23, 2005 11:10 PM
