Electrical Problems
Old Oct 19, 2011 | 05:59 AM
  #11
simxxi's Avatar
A loose or bad ground will cause all kinds of havoc. I replaced mine from the battery to the back of the engine when I started having weird electrical problems. Headlights would automatically close, sometimes start, sometimes the display lighting would flicker. The regulator on the alternator can go bad as well, not receiving a good ground, or a short circuit if something is hooked up backwards even if a new stereo is hooked up wrong. The other electrical issue I had besides the bad ground from the battery was the DME. It had a mind of it's own. Car would start right up and after about two minutes it would die. Sometimes it ran fine for days. I had the DME tested and the tech found three bad components and replaced them. DME repair was $100.00 Now it runs great. Prior to that I replaced the fuel pump relay, fuel pump and the reference sensors. Only thing left was the DME. Mine too is an 87 924S.
Old Oct 19, 2011 | 09:15 PM
  #12
gregjay's Avatar
Default porsche 944
Hello Guys I am new to this forum and happy I found it I bought a 944 that just lives in the shop but when it runs I love driving it My recent problem is I have a red wire that comes off the secondary fuse panel where the fuel pump fuse is my guess it is either 12 or 14 gauge solid red that goes somewhere and i have no idea where this wire attaches? It appears to be the only solid red wire under there and the fuel pump is not working . Any ideas would help and ideas on where to find a goood clear wire diagram would help beacause the front harness needs to be replaced as well Thank you guys greg
Old Oct 20, 2011 | 09:33 AM
  #13
gregjay's Avatar
Default Sounds like the same car
I to replaced all the items you mentioned except for the DME All of my problems started with a loose or faulty wire that caused the headlights to go up and down until they stuck and burned the wires thru the harness its been a nightmare since. Car runs great for a day then shuts down and doesnt start back up a day later runs for 2 minutes and shuts down again I will look into that DME
Old Apr 15, 2012 | 10:57 AM
  #14
gregjay's Avatar
Default 1985 porsche 944
I am having a problem finding the location of this wire under the dash it is red and black approx 18inches long with two female ends and is not aftermarket any ideas [IMG]file:///C:/Users/Amy/Desktop/photo_JPG%20-%20Gmail_files/photo.JPG[/IMG]
Old Oct 16, 2012 | 01:17 PM
  #15
gregjay's Avatar
Default 944 crank sensor
Still havent found why I am not getting any spark on my 944 can anyone tell me what the crank sensor relays do?
Old Nov 11, 2012 | 08:33 AM
  #16
Gooseman's Avatar
You should try searching for a driver's manual. Maybe that can help you in some way. My dad had some issues with his Land Rover. I downloaded a manual and found the exact answer to what was bugging him.
whiplash_s
Feb 19, 2008 07:56 AM
BOBTHEBUILDER
Oct 3, 2007 08:55 PM
wvumoose
Jul 24, 2007 02:10 PM
Toffie10
Apr 16, 2007 04:24 AM
BOBTHEBUILDER
Jun 29, 2006 09:27 AM
