Broken Lug Nut HELP!!!
Old Aug 26, 2007 | 09:16 PM
Will Swain's Avatar
Default Broken Lug Nut HELP!!!
I have a broken lug nut on the rear drivers side of my 1984 928S,I need too replace the rear tires and just cannot get a hold on the nut because its is gone except for a minute amount.
PLEASE HELP.
Old Aug 26, 2007 | 09:45 PM
Default RE: Broken Lug Nut HELP!!!
On the aluminum lug nuts, typically I take a 12 point deep well socket and pound it with a large hammer so it digs into the aluminum socket. Then using a long breaker bar, remove the lug nut. It will not work using an air impact gun, you must use the breaker bar and put slow pressure to it.
Old Oct 16, 2007 | 02:23 PM
Shogun1011's Avatar
Hmm...same problem here!! what happens if the lug is so "gone" that it's almost flush with the wheel? I tried the "smaller socket" bit, but there was so little left, that the socket just shredded it. Should i drill it out a little bit a time? i'm completely stuck here. The tire needs to be removed to replace a wheel bearing and front brakes. Otherwise, the car is undrivable.
I'm actually amazed that porsche would use such light weight, seeminly weak lugs.Am i missing something? is it bad to use steel lugswithfuchs wheels?
trussard
Oct 13, 2015 06:52 PM
Jrbraker85
Feb 24, 2011 07:50 AM
CMXI
Jan 20, 2008 10:34 AM
Acadist
Jul 22, 2007 01:13 PM
nankipoo
Jul 29, 2006 12:40 PM
