flywheel timing sensor
Old Sep 21, 2007 | 09:57 PM
tommyshark's Avatar
Default flywheel timing sensor
reviewing the 1985 euro 928 s and inspection showed the flywheel timing sensor connector completly destroyed. after cutting the male ends off i noticed what started as a blue red black wiring ended up with a yellow and black wire .
what is going on ? there were two little black wires that pulled right out of the sheathing
i assume they were the blue?
what does it really need to work. the female end is creme red and black
thanks for your help.
Old Sep 22, 2007 | 03:14 PM
Default RE: flywheel timing sensor
Boy, I just don't know the wiring of a 928 unfortunately. Hopefully someone here has some experience. There are also some decent 928 boards out there that might have some knowledge. I would try over on rennlist and see if they have some info.
magnew
Nov 17, 2008 08:07 AM
Panzer
Aug 23, 2007 11:44 AM
nussairh
Aug 13, 2007 02:54 PM
Mr Pilkington
Aug 20, 2005 01:18 AM
zoom_928
Jul 31, 2005 01:35 PM
