90 S2 Heater will not shut off
Old Jul 15, 2005 | 03:27 PM
bajabubba40's Avatar
Default 90 S2 Heater will not shut off
My mechanic is scratching his head. Anyone experience this?
Thanks
Old Jul 15, 2005 | 03:52 PM
Default RE: 90 S2 Heater will not shut off
Are you talking it blows heat all the time, or the blower fans won't shut off at all? If it is constantly hot air, check the vacuum lines at the heater control valve and the firewall, and if those are intact, then there is a clip on the control unit itself that tends to break and is a quick easy replacement. If the fans are always on or only blow at one speed, then clean the resistor under the plastic cowl next to the fuse box.
bmac1990
Jan 25, 2009 09:24 AM
FSUKXAZ
Oct 28, 2008 10:57 PM
O2996
Aug 14, 2008 11:36 PM
redondo911
May 8, 2007 02:06 PM
redondo911
Apr 23, 2007 08:29 PM
