944 timing belt jumped
Old Sep 3, 2008 | 09:42 PM
ncipps's Avatar
Default 944 timing belt jumped
Hello Everyone,
I am interested in a porsche 944 83. its a pretty clean car however the owner states the timing belt jumped a tooth. he said it will idle however it runs very rough. I always thought if it jumped a tooth it was trash. is this owner correct or am i opening a can of worms.
Old Sep 3, 2008 | 10:13 PM
Default RE: 944 timing belt jumped
You can be a tooth or two off and not have any valve damage, but I would verify how far off it is before buying.
Old Sep 3, 2008 | 10:20 PM
ncipps's Avatar
any idea on how to check or verify this?
Old Sep 4, 2008 | 07:09 AM
Fast951's Avatar
You'll have to remove the timing belt cover and check the alignment mark on the cam gear versus the indicatoron the engine to see if the timing is off. At TDC (Top Dead Center) on cylinder #1 the marks should be aligned.
obboardcamera
Jan 25, 2007 12:12 AM
88_944
Nov 22, 2006 09:51 PM
drummer_toxik
Jun 30, 2006 12:43 AM
luckybuster
Mar 27, 2006 12:04 PM
ichosun1i
Sep 1, 2005 12:01 AM
