944 tire and rim sizes
Old Aug 23, 2009 | 10:49 AM
944speedy's Avatar
Default 944 tire and rim sizes
Hey all;
I have a 1986 Na with standard NA telephone Dial rims. The tires currently on the car are 215/60/15 and 225/60/15 which look like tractor tires. Id like to install the proper turbo size tires (I like the look of different tires in the front vs. back). I think these are the specs. 205/55 VR 16 215/60 VR 15
Can I install these on my rims or do I have to change the rear rims to accommodate? I am not sure of the rim specs.
If someone could let me know the rim specs needed, if my tire size specs are correct and any possible variations using my rims, that would be much appreciated.
Thanks guys.
Speedy.
Old Aug 23, 2009 | 05:06 PM
You can install 1986 944 Turbo rims in 16x7 and 16x8. You can run 225's up front and 245's if you want, or run the stock 205/225's.
Old Aug 25, 2009 | 11:20 PM
944speedy's Avatar
So without changing the rims, what are my options right now? What would you put on? And I read this for turbo sizes...does it make sense? 205/55 VR 16 215/60 VR 15
Thanks Doc.
S.
Old Aug 26, 2009 | 10:08 AM
No it doesn't make sense, because you are inferring that you are using 2 different rim sizes, one a 16" and one a 15" The NA cars came with 15" rims, and the turbos came with 16" rims. That will upset the cars handling for sure. If you have stock rims on the NA, then you have 15" rims. You can't install a 16" tire on a 15" rim. You will have to stick with tires such as a 215/60/VR15 all the way around.
Old Aug 27, 2009 | 10:33 PM
944speedy's Avatar
Yes of course, that makes sense. Reading back, it was a lame question. Thank you for your patience.
S.
Old Nov 6, 2011 | 11:36 AM
bobdeacon's Avatar
Default '86 944 (not Turbo) tire question
The stock tire size is 215/60/15 for this car. I currently run 225/60/15 on it with no problem but I recenly blew one out and wish to replace the set as they look too big and truck-like.
My question is this:
Question #1: Can I install 225/55/15 tires all the way around without causing issues?
Question #2: Can I install 245/50/15 on the REAR, 225/55/15 on the FRONT without causing issues?
Reply here AND to deek1@lightstream.net
Thanks.
ehren_henderson
Dec 21, 2012 06:38 AM
Roman
Sep 20, 2009 03:49 PM
cube
Dec 14, 2008 03:30 PM
damagicman98
Dec 17, 2007 04:01 PM
EthanDuce
Jul 20, 2006 01:42 AM
