air con.
There is no PCV system on these cars, it uses an oil air seperator. Blue smoke is obvioulsy oil as you suspect. I would do a leakdown and compression test and that will give you a good idea of what is going on in the head and with the rings. I suspect the turbo is going bad, and i have seen it in turbos with far fewer miles than 6k. Doing the leakdown and compression will rule out the engine, and will leave you with the turbo. I would also pull your intercooler pipes and see if you have any oil in the tubes. A little is normal, a lot is not.
