All Most a big problem!!
Old Apr 25, 2005 | 01:01 AM
mmyeah's Avatar
Default All Most a big problem!!
I am a recently new owner of a 84 944, I gave the car a tune up this weekend and repalced all the hoses and belts...while changing the belts I noticed that the upper turnbuckle was broken...split right where the eyebolt meets the cylinder. The only thing holding the turnbuckle together was the pressure from the altenator and the AC compressor...yeah not good one good bump good have sent both crashing inwards!! I found a replacement from an old junker at a yard (with some other cosmetic upgrades) and fix the issue...my question is does the turnbuckle break often? It is one of the easiest and best belt tention systems I have ever encountered but if broken could cause some hefty damage. Will I have to replace this again or was the issue due to previous owner not losening the eyebolts before trying to release tention therefore breaking the piece? Anyone have this problem? Sorry for the long post...thanks for any responses...
Old Apr 25, 2005 | 12:02 PM
sh944's Avatar
Default RE: All Most a big problem!!
You nailed it. It should hold up fine for the life of the car, unless ErnieBob tried to adjust it with Channel Locks without releasing teh tension. Pretty much every 944 I have ever come across had that problem with either the power steering or ac adjustor (and occasionally both).
Regards,
fstazzwhip
Mar 25, 2008 02:37 AM
Lee Willis
Dec 21, 2005 12:44 PM
Patrick
Dec 16, 2005 04:15 PM
1972 911S
Apr 26, 2005 02:54 PM
Rolo
Feb 17, 2005 08:57 PM
