cooling fan
Old May 7, 2007 | 06:23 PM
riker's Avatar
Default cooling fan
sometimes when i park my 87 944 the cooling stays running and wont turn off, so i have to remove the fuse. im thinking a malfunctioning sensor? any ideas? also what's normal psi at the fuel rail from the fuel pump? thanks.
Old May 7, 2007 | 08:13 PM
JustinK's Avatar
Default RE: cooling fan
Usually the fan will stay on for a period of time when you shut off your engine, but it should turn itself off once it's cooled.Does the fan come back on when you put the fuse back in? If so, than mostlikely its a badfan switch. Here's a link to one of the forums sponsorsite with what you should need. You've got two temperature choices.
http://www.getcoolparts.com/epcvsoap...d=getcoolparts
Old May 7, 2007 | 11:31 PM
Fan Switch. I don't run anything but the cooler one.
KM5TZ
Sep 26, 2008 05:55 PM
milotype2
Mar 30, 2007 07:24 PM
POORsche Chuck
Feb 23, 2007 08:35 PM
Glyn
Aug 22, 2005 01:19 PM
BAShibby21
Feb 5, 2005 06:04 PM
