Cooling Fans
Old Jul 1, 2007 | 02:01 PM
Acadist's Avatar
Default Cooling Fans
Went out today to see if I could trace my running warm problem down. After letting it idle up to temp only one of the fans came on. Is it safe to assume that if one fan works and one doesn't that it is the fan motor or do they run on seperate systems? The wiring looks ok. I also found a couple of connectors for hoses (vacuum?) that are not connected......one is under the mass air flow meter on the front of the engine, it is large (probably .5-.75") and another one is on the passenger side and is next to the where the radiator hose goes. That connection is plastic and is directly behind the fan that is not working.
Old Jul 4, 2007 | 12:17 PM
riker's Avatar
Default RE: Cooling Fans
it isn't safe to assume. Turn on your AC and see if the other fan comes on, if the other fan comes on then its not the motor obviously. Is it the driver, or passenger side fan that comes on when you're idling?
Old Jul 4, 2007 | 01:51 PM
Yup, start by turning on your AC, then the other fan should come on. Typically one fan not working is due to a faulty fan or ac relay.
Old Jul 4, 2007 | 05:58 PM
Acadist's Avatar
It is the driver's side that comes on.
100dollarcar09
Sep 16, 2008 08:07 PM
mytrplseven
Mar 31, 2007 01:42 AM
milotype2
Dec 17, 2006 03:14 PM
911mct
Nov 13, 2006 08:51 AM
docaudio
Jun 15, 2005 08:30 PM
