Few Tech Questions
Old Sep 23, 2010 | 02:50 PM
Jackstripper01's Avatar
Default Few Tech Questions
Hello everybody! My names is Logan and just a few weeks ago I bought a 84' Porshce 944. Its a beautiful car and I love it. There are just a few questions I had that I was hoping anybody on here could help me with.
First off, sometimes when i turn left, and ONLY when i turn left the car will make a sound as if there is something in the front part of the car that rubbing against something else. I checked to make sure my tires werent rubbing against the inner part of the car when the wheel is turned and it wasnt anywhere close so i have no idea what this could even be. It doesn't happen all the time, ususally if i am turning really slow it will make the noise but other than that I never hear it.
Secondly, I read somewhere that this was an issue with these models up until late 85 or 87 but sometimes the car will vibrate really bad (even with the A/C off) for a few seconds when i stop and then will suddenly stop. Is there anything i can do that will dampen the vibrations?
Then lastly, i see that there is not very much room in the hood and i was looking to put a turbo into the car so that it was a little bit faster than the later models. Is this at all possible or is it going to cost me more than an arm and a leg?
Thanks for anyhelp you guys can give and I attached a photo of the car to the post. Isn't she just beautiful?
Old Sep 23, 2010 | 02:51 PM
So i guess that attachment didn't work? I am such a noob =/
Old Sep 23, 2010 | 08:31 PM
1. Right front wheel bearing
2. mmm shouldn't be any vibrations
3. You will dump far more money trying to turbo your car than to just go by a 944 turbo.
Old Sep 23, 2010 | 09:38 PM
Well I forgot to add that it only vibrates when I am idling and is the right front wheel bearing costly to repair or is it something I can do myself?
Old Sep 24, 2010 | 12:40 AM
Bearing is probably 30 bucks in parts, but you need to be able to press the race into the hub, which usually requires a press. You can do it by heating the hub in the oven and using a bearing race driver to put in the races, though if you are married/engaged/living with a significant other, you may find yourself in a bit of trouble for cooking car parts in the oven, lol.
Old Sep 25, 2010 | 01:03 PM
Haha yeah I'm not sure that will go over well, I'll just call a shop and see how cheap I can get it done. Thank you for all the help!
Mark944
May 7, 2007 12:30 AM
Last Of The R/Ts
Mar 4, 2007 01:24 PM
porsche924turbo
Feb 16, 2007 04:17 PM
ZinFaren
Feb 10, 2007 05:06 PM
CO951
Aug 4, 2005 05:32 AM
