In need some help here !!!!
Old Feb 2, 2007 | 04:04 AM
koreng's Avatar
Default In need some help here !!!!
I got a problem with my 944, my clutch pedal wont work. instead it keeps pushing until the end(max) and as for that, i cant put in at any gears neither do gear 1 nor 2. Something to do with leaking? Any help from experts. Thnaks in advance !!!
Old Feb 2, 2007 | 11:12 AM
Default RE: In need some help here !!!!
Does the clutch pedal operate normally? I.e. does it come back up when you release it, or do you push it to the floor and it stays there?
If it operates normally, then your clutch is shot.
Old Feb 2, 2007 | 01:30 PM
koreng's Avatar
Thnaks doc, no it does not come back when i press it. it stays down. How can i solve it?Thx for ur reply.
Old Feb 2, 2007 | 03:44 PM
Then you have a bad master or slave clutch cylinder, or a hole in the line between them.
First check your brake fluid reservoir and make sure it is full. If it is, then you are looking at replacing the cylinders.
My advice is to replace all 3 items at the same time, because if you do one, the other will fail shortly there after. I have seen it happen a lot.
EmpireCustomComposites
Jun 6, 2010 10:59 PM
mhariush
Dec 21, 2007 09:43 PM
symbiote
Nov 9, 2007 07:54 AM
backyard_engineer
Mar 22, 2006 03:30 PM
Chris945
Dec 10, 2005 07:45 PM
