No fuel........any help?
Old Feb 19, 2009 | 04:43 PM
AJB85944's Avatar
Default No fuel........any help?
A while back after I got my car back from the mechanic due to a busted cam my car caught on fire in my driveway. Needless to say, I was pissed, but there was nothing I could do so I decided to fix it. I replaced the fuel rail, distributor, spark plugs and wires, fuel injectors, and the speed/reference sensors. Unfortunatley, I still have a non-running car. I have traced the problem down to a fuel problem. My fuel rail isn't getting any gas, therefore, no fire. does anyone have any ideas what might be causing this?
Old Feb 19, 2009 | 07:06 PM
AJB85944's Avatar
Default RE: No fuel........any help?
Ok, fixed the fuel problem. Now I have a firing problem. It turns over and sounds like it wants to fire, but it won't. I'm thinking I have the distributor cross wired. does anyone have a diagram of the order that they are supposed to be hooked up in?
Old Feb 19, 2009 | 07:32 PM
grayghost951's Avatar
Starting at the bottom right terminal going in a clockwise direction the order is1-3-4-2.
Old Feb 19, 2009 | 11:07 PM
AJB85944's Avatar
Ok, I got it wired right. But it's still not firing. I also have a hissing noise coming from my fuel pressure regulator (as best as I can tell anyway) any idea what might be causing this?
porschestylexx
Aug 21, 2008 12:29 AM
porschestylexx
May 14, 2008 08:19 AM
ultimateballa
Mar 6, 2008 01:22 PM
srivers33
May 3, 2005 12:08 AM
sapper944
Aug 29, 2004 01:26 PM
