The odometer fix
Old Nov 11, 2007 | 11:12 AM
tc97's Avatar
Default The odometer fix
Whats the part that you need to get to fix the odometer when it stops working and is there a write up some where? Also my gas gauge stops at half way full is this common, is it just the float in the tank or is it in the dash?
Old Nov 11, 2007 | 12:40 PM
tc97's Avatar
Default RE: The odometer fix
I ment is the problem in the dash not the float.
Old Nov 11, 2007 | 03:36 PM
Rennbay has the odometer gears.
The float in the tank runs on two extremely thin wires, sometimes the wires will get gummed up and won't ride correctly.
Old Nov 11, 2007 | 03:47 PM
tc97's Avatar
Sorry I am new, what is rennbay?
Old Nov 11, 2007 | 03:52 PM
tc97's Avatar
Ok I found it but does the part come with instructions, it did not say on the site.
Old Nov 11, 2007 | 04:09 PM
I dont know, it isn't exactly rocket science. Pull the cluster, pop the screws off the back to separate the cluster and figure out the install from there.
Old Nov 11, 2007 | 04:12 PM
tc97's Avatar
Thats what I thought but it seems like a common thing that goes wrong so I thought there might be a very specific write up so that people could just blow through it. But I will just wing it like you said its not rocket science
Old Nov 13, 2007 | 10:21 AM
RATNIK's Avatar
Here is one of the guides, the site doesn't provide a direct link but go here: http://www.clarks-garage.com/ and than click on "Garage Shop Manual" on the left side, scroll down to letter "O" and click on "Repairing Odometer" scroll down just a bit until you see "Other Procedures Needed" and under it click "ELECT-07, Removing Late 944 (1985.5 and newer) Gauge Cluster", that should get you pretty far.
Old Nov 13, 2007 | 08:15 PM
Acadist's Avatar
Easy fix, already have done it. Clark's garagehas great instructions. I was also having the same problem with the gas guage, I loosened the sensor and jiggled around and now it works fine.
Johnny Carson
May 13, 2007 07:31 PM
88_944
Dec 10, 2006 12:58 PM
drudyscott
Dec 5, 2006 11:14 PM
911sccoupe
Jul 30, 2006 03:31 AM
BAShibby21
Jan 23, 2005 02:49 PM
