rims and tires for a 944 t
Old Jan 14, 2007 | 09:49 AM
obboardcamera's Avatar
Default rims and tires for a 944 t
what the biggest set of rims and tires I can install on a 944 t without hurting anything, and does anyone have any suggustions of makes and models?
Dirk Pitt
Old Jan 14, 2007 | 02:23 PM
Default RE: rims and tires for a 944 t
You can run up to 18" rims with up to 285 tires in the rear (with the correct spacers). Porsche does not recommend using larger than 17" rims though, and I think 18" rims are too much on a 944.
Old Jan 15, 2007 | 07:21 AM
CTiggerPigglet's Avatar
I think 18" rims look great on a 944, but if you are fitting wider rims tramlining will increase. You can help reduce this by fitting a anti-roll bar though.
Your right PorscheDoc, Porsche does notrecommend that you fit rims any larger than 17", but they then fitted 18" rims to the very limited edition 968 turbo. So they sort of contradicted themselves there![&:]
Justinw23
Mar 8, 2013 04:27 AM
v4vivian
May 11, 2010 04:19 PM
pinto096
Jan 18, 2009 06:24 PM
sempaipaul
Nov 12, 2008 09:16 AM
nippy
Nov 20, 2006 01:50 AM
