starting problem
Old Mar 29, 2006 | 11:49 PM
willie944's Avatar
Default starting problem
i had asked before about a 83 944 not starting. the reply was tdc sensor or speed sensor since i have replaced dme already. no fire no fuel. is there any way to find out which sensor it is without replacing both????????????
Old Mar 30, 2006 | 12:39 AM
Default RE: starting problem
Did you replace your DME relay first? www.clarks-garage.com in his shop manual tells how to test the speed and reference sensors.
Oh, first, is your tach bouncing at all during cranking?
Old Mar 30, 2006 | 11:25 PM
willie944's Avatar
no the tach is not bouncing.
Old Mar 30, 2006 | 11:26 PM
willie944's Avatar
yes i did replace dme.
Old Mar 31, 2006 | 12:44 AM
Did you replace the DME (ECU) or the DME relay? Ok, if the tach isn't bouncing either the DME is bad, DME relay, or the reference sensor is bad (front sensor). I believe the car will start with a bad speed sensor.
Old Jul 6, 2006 | 12:02 AM
c90scampbell's Avatar
PorscheDoc Thanks for the info. I was having issues getting spark. I started checking the DME wiring and found a broken pug behind the engine. The Tac still doesn't move during cranking, but will move when fired up.
amirsabreeisgod
Oct 10, 2005 09:33 PM
corbovit
Sep 15, 2005 08:10 PM
kevfran
Jul 30, 2005 03:53 PM
dwendt
Jul 20, 2005 02:27 AM
cycotic_penguin
Apr 8, 2005 07:16 AM
