Still no spark...
Old Mar 6, 2007 | 05:19 PM
TheCarFarm's Avatar
Default Still no spark...
Still have power to the coil with the key in the on position...lose power when I turn the key to crank.
Pulled the ignition relay from the column. Cleaned the connections and they all look good. No luck.
More suggestions are greatly needed.
Thanks.
Old Mar 6, 2007 | 09:39 PM
kinderrich's Avatar
Default RE: Still no spark...
If you remove the hot wire from the coil does the voltage still drop off when you turn the key?
Old Mar 7, 2007 | 02:35 AM
TheCarFarm's Avatar
Yup, Everything loses power. All guages and lights, when turning over.
autoworldcorp2000
Jul 27, 2007 09:16 AM
willie944
May 10, 2006 06:01 PM
Mr Pilkington
Feb 15, 2006 01:59 PM
White Pony
Jul 13, 2005 02:24 AM
taktiks
Aug 31, 2004 07:31 PM
