Throttle Position Sensor
Old Dec 10, 2010 | 07:32 PM
84944s's Avatar
Default Throttle Position Sensor
Hi Folks,
Having recently experienced what I've been told is called 'hunting' idling and power loss at 3000rpm, I've just purchased a new Bosch Throttle Valve Switch (TPS). Is this sensor difficult to install? It looks fairly straight forward ...but that's what makes me nervous. Would someone have some advice regarding installation procedure and adjustment requirements for doing it myself, or am I off to see the Doc?
1984 944 na.
Old Dec 13, 2010 | 10:34 AM
951jamie's Avatar
one of the problems with the early 944 - 85/1 type cars - is that the DME is pretty rudementry - and is prone to stumbling and other " issues "
the BEST around this is to replace the early DME/ afm with another set from the later 85/2 cars and one more good thing about the update is that it can then be chipped !! -
click on this link and it will give you the list of DME's and AFM you can use
http://www.944online.com/cgi-bin/for...num=1223732377
imodvek
May 24, 2013 09:11 AM
Agent31
Oct 22, 2007 07:45 PM
Vashuta
Sep 3, 2007 11:28 PM
Skywalker
Apr 16, 2007 08:11 PM
jwagner76
Oct 11, 2005 04:06 AM
