water in the oil
Old Feb 24, 2008 | 05:03 PM
kinderrich's Avatar
Default water in the oil
So I bought a 1986 NA 2.5L from a junkyard. The compression was good in all four holes and the water pump looked recent. The rear balance shaft seals were bad, so I replaced the front/rear seals and oil pump seal. I have an 87 oil pan so I decided to put that on. I drain the oil and found about a pint of water. I didnt see this engine run, but when I picked it up I didnt see water in the oil or on the dipstick. I have had this on the engine stand for a couple of weeks and had it turned on one side then the other. My question is could this water get in any other way than a bad head gasket?
Old Feb 25, 2008 | 08:38 AM
Default RE: water in the oil
No, shouldn't be water in there. I would pull the head gasket and replace that since you have it on a stand anyway.
Old Feb 25, 2008 | 05:01 PM
q5ka's Avatar
There is also the oil cooler that may have caused the leak. Since you got the engine out, replace those seals also and prevent a bigger headache down the road. A few dollars to save hours of work.
Dr944S2
Nov 24, 2014 12:42 PM
Barbied0ll
Jan 6, 2009 11:54 AM
jordan2011
Mar 29, 2008 09:41 AM
mechcyber
Sep 5, 2007 04:08 PM
jeff_rx7
Mar 25, 2007 10:44 PM
