water pump bolt broken
Old Mar 2, 2008 | 10:34 AM
kinderrich's Avatar
Default water pump bolt broken
Replacing the water pump on an 86 NA two of the bolts broke off. I got one out , but had to drill the other. Is it better to use a heli coil, or just tap the hole for a bigger bolt? This bolt is the inside/top bolton the water inlet.
Old Mar 2, 2008 | 11:06 AM
Default RE: water pump bolt broken
I would actually use a time sert, it will hold much better. Keep the size the same.
Old Mar 2, 2008 | 03:29 PM
kinderrich's Avatar
That seems to be best, I see a distributer in Texas, but not exactly clear how to order a kit. Is there some where on-line to get these. I am in Oklahoma City, but dont see any local vendors. Where do you buy them?
milotype2
May 30, 2007 05:15 PM
ZinFaren
Mar 15, 2007 08:42 PM
sam un ont
Jan 26, 2007 08:40 PM
confederatelowrider
Aug 16, 2006 09:15 PM
Gapowr99
Jan 19, 2005 02:35 PM
