Boxster Coolant overflow/leak
Old Apr 26, 2007 | 12:25 PM
rockstarr's Avatar
Default Boxster Coolant overflow/leak
I am having a problem with the Coolant periodically leaking out and then it stops. Did a leak check and nothing. Anyone have this problem before?
Old Apr 26, 2007 | 03:19 PM
Default RE: Boxster Coolant overflow/leak
There is an updated radiator cap that is recommended for the boxster. The old one does have problems. The coolant tanks are also prone to cracking, but if you coolant level is fine, then it is probably ok.
Bobiam
Jan 1, 2008 08:02 PM
mnchstrcityblues
Jul 28, 2007 01:39 PM
wdonovan
May 29, 2007 08:18 AM
brianeshen@msn.com
May 27, 2007 11:57 AM
goebels97
Nov 30, 2006 01:09 PM
