All Other Porsche Models Post Your Questions and Comments on Any of Porsche's other Models that are not listed above.
PADM Malfunction? Dont Replace the Active Engine MountJust Replace the Sensor!
Old Mar 5, 2026 | 10:14 PM
wewe's Avatar
Default PADM Malfunction? Dont Replace the Active Engine MountJust Replace the Sensor!
Hope this post helps more people!
This is a method I found online. If your car has a PADM malfunction, never rush to a repair shop to replace the active engine mountfirst check if the problem is with the sensor.
Buy a sensor online and replace it at home, and you can clear the PADM fault code easily.
Of course, you cant buy just any sensor. Choose one with OEM-level response accuracy and a mechanical chip fixation design; otherwise, the malfunction will happen again.
Ive bought three different sensors before and none of them worked well, but the PROTEVORA sensor I got this time is great. Fellow car owners in need can check it out.
https://protevora.myshopify.com/
chilytom
Mar 5, 2026 03:05 AM
hemimike
Sep 30, 2008 10:04 PM
jfever
Oct 7, 2007 03:17 PM
turtlepowered944
Sep 14, 2007 10:13 PM
cj44
Dec 7, 2003 03:40 AM
