Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification... let's hear about it here...
Install question for aftermarket Nav
Old Oct 17, 2007 | 12:16 PM
hatcher's Avatar
Default Install question for aftermarket Nav
Does anyone know where/how the amp is wired for an 02 Cab that is going to have a Pioneer AVIC D3? Also is the antenna amplified on that car?
Old Oct 21, 2007 | 09:34 PM
ESOTERIC's Avatar
Default RE: Install question for aftermarket Nav
most likely the amp is wired with a low level signal in a smal plug behind the radio, cut the plug because the grounds of the audio signal are all connected together (the brown wires) also the antenna wire is white i think on porsches, and you might be lucky to have the speed pulse wire back there also, off the top of my head it is gray/pink I think
Old Oct 22, 2007 | 01:47 PM
hatcher's Avatar
thanks alot for response
Old Oct 24, 2007 | 02:51 PM
hatcher's Avatar
One other question is how doesmy double din PioneerAVIC D3 stay mounted. What holds the unit in and keeps it from sliding out? I probably should have said earlierthat im moving the ac unit down in the cd holder area.
AUDIOTISTICS
Nov 1, 2007 07:11 AM
propdave
Sep 1, 2007 04:08 PM
hadakaneko
Jul 25, 2007 11:03 PM
Porsche3045
Apr 24, 2007 12:26 AM
vlude99
Jul 12, 2006 09:07 AM
