timing belt-valves
Old Jan 12, 2009 | 09:16 AM
pyradell's Avatar
Default timing belt-valves
I am in the process of getting a 1983 Porsche 944. The timing belt broke for it and was told that it might and most likely has bent valves. What valves?
Old Jan 12, 2009 | 10:38 AM
Default RE: timing belt-valves
Yes, the valves in the head are going to be bent if it broke the timing belt. There are 8 valves in the head, and you can typically bet that 4 of them will be bent at least. You won't know if they are the intakes or the exhausts until you pull the head. I would plan on installing new valve guides and seals while you have the head off. Get it trued up, new valves installed, and put it back together. You should be doing the rollers and waterpump and new belts when you put it back together so you don't have this problem again. Figure anywhere from $500-750 doing the work yourself.
obboardcamera
Jan 25, 2007 12:12 AM
88_944
Nov 22, 2006 09:51 PM
drummer_toxik
Jun 30, 2006 12:43 AM
luckybuster
Mar 27, 2006 12:04 PM
ichosun1i
Sep 1, 2005 12:01 AM
