low oil
Old Jan 11, 2009 | 11:50 AM
newfielablovers's Avatar
Default low oil
I recently purchased an 87 911. By the time I took delivery, I noted the oil level (dipstick) was low. It took just over5 quarts of synthetic to bring the level to acceptable. Oil pressure is/was ok. Do I need to be concerned? Thanks!!
Old Jan 11, 2009 | 02:25 PM
pete917's Avatar
Default RE: low oil
Did you check it previously and was it full?
Have you noticed any leaks?
Is it smoking?
It seems like alot of oil to me....
tell us more
Old Jan 11, 2009 | 02:47 PM
Default RE: low oil
No leaks, just a puff of smoke when cold starting. It was low when I took delivery- not sure when the previous owner last checked it. He changed the oil appox. 3,000 miles ago and I suspect he did not check it since. Runs fine, but I'm just concerned re possible damage to the engine while it was low...
Old Jan 11, 2009 | 03:02 PM
pete917's Avatar
Default RE: low oil
Worse case if it became very low is that you would suffer oil starvation to the big ends and they wear excessively.
However, it may well be the case that the previous owner didnt fill it properly in the first case. If you dont get the engine hot after putting in an initial 9 litres, say, then check again you wont have fillied the oil cooler and oil lines going to the front.
I personally only run with the oil half full according to the dipstick.
I would say keep the oil topped up (with a good oil) and make sure you check the oil level only when the engine is running and at operating temperature.
Old Jan 11, 2009 | 03:25 PM
surfer's Avatar
Default RE: low oil
As pete917 has said, make sure the level is checked while the engine is running. Also check the level gauge in the vehicle @ full oper. temp.
[IMG]local://upfiles/7694/981C950187C94DD0A2FDD29BBFCF30CA.jpg[/IMG]
Old Jan 11, 2009 | 08:50 PM
Default RE: low oil
Yes, hopefully you checked the oil with the engine running, and at operating temp. If you checked it cold, and with the engine off, then added oil, you are going to be overly full and will probably blow the seals out.
Old Jan 11, 2009 | 11:29 PM
Default RE: low oil
Yes - The engine was at normal operating temp. (and running) when the oil was checked... I'm going to have my mechanic check things out but I still suspect the previous owner did not account for normal usage, possibly in combination with inadequate filling at the last oil change. Thanks for everyone's input!!
Old Jan 12, 2009 | 08:04 AM
Default RE: low oil
You are probably correct on an incorrect fill then. For the car to go through that much oil, it would have to have a major leak (which you would see on the ground), or be burning it so bad you wouldn't be able to see behind you.
donny
Oct 9, 2007 07:48 PM
Chris
Sep 24, 2007 08:35 AM
Skywalker
Jul 1, 2007 01:44 PM
Panzer
Jan 22, 2007 04:23 PM
kinderrich
Dec 28, 2005 11:35 PM
