2000 996 oil change
Nothing to it. One drain plug which takes an 8mm allen. Filter is at the bottom of engine in a canister, can't miss it. You will need a filter wrench to get it off (type that slides on the end of the filter). Inside is a paper filter OC128 is the mahle part number. Make sure you replace the rubber O ring on the canister (it comes with the filter), as well as get a new crush seal for the drain plug. Mobil 1 0w-40 8.5 quarts to start with. Bring engine up to operating temp, turn off engine, check oil after a minute or so.
pdhamilton
Dec 5, 2008 03:00 PM
