944 not starting
Old Jun 9, 2007 | 08:01 PM
stretchx13's Avatar
Default 944 not starting
I have a87 944 that I recently purchased that was not running. The owner claimed the timing belt was off by a few teeth when it was replaced and never got fixed, then sat for two years. When I looked at the belt it was off by three teeth counter clockwise. When I fixed it I misread the instructions for the timing belt setup and put the camshaft gear about 1 tooth counterclockwise from the mark when the flywheel was at TDC. The car started up and ran but would die if my foot was off the gas. I checked the instructions again to see what was the cause, realised my mistake set both marks at TDC at the same time and now the car won't start. The engine is getting gas (I pulled the pulss and they're wet with it), itsalso getting spark at all four plugs, using a multimeter I checked the speed sensor and it gets two volt spikes, the reference sensor only gets a 0.5 volt spike, but the tach bounces slightly when the engine is spun. Is there anything I'm missing? Any help would be greatly appreciated. Thanks
Old Jun 9, 2007 | 10:22 PM
Default RE: 944 not starting
Do a compression test and post the results.
Old Jun 12, 2007 | 10:55 PM
stretchx13's Avatar
The compression test results are 0 psi for all four cylinders and the gauge did not move when the enginge was rotating. When I did the test I jammed the throttle all the way open and the gauge hose was threaded pretty tight. Also the gauge works as I tested on one of my other cars. Is no reading at all normal for bent valves or did I not do the testing the porper way?
Old Jun 13, 2007 | 07:26 AM
Then you have bent valves I am afraid. You have at minimum 4 bent valves (one in each cylinder, hence the no compression), so you are looking at a pretty heafty repair bill, even doing the work yourself. You might want to start looking for a good used replacement head, as it will be cheaper than buying all the valves.
Old Jun 14, 2007 | 10:42 PM
stretchx13's Avatar
Thanks for the help PorscheDoc. You were right about the valves, all four of the intake valves were bent and at least one of the exhaust valves as well.
If I were toreplace the valves myself what parts wouldneed besides the valves themselves? And is it common for the valve seats to be damaged from the bent valves?
war
May 5, 2009 12:23 PM
kotoole
Jul 6, 2008 11:56 PM
smkdhog
Jan 12, 2007 01:50 AM
CTiggerPigglet
Jun 28, 2006 12:59 PM
brandnewday
Mar 9, 2005 12:34 AM
