77 911 with 3.2 engine not starting
Old Jul 5, 2008 | 11:13 AM
kotoole's Avatar
Default 77 911 with 3.2 engine not starting
Hi all, this is my first post im new to the 911 and have upgraded from a 944
I have a 77 911 with a 996 body and a 3.2 engine
When I try to start the car I get the red lights on the dash and when I turn the key to postion I hear a click noise like the solanoid but the engine dosent turn
I tried changing the battery and have the same problem
Any ideas if its the starting motor is it easy to replace?
Thanks
Ken
Old Jul 6, 2008 | 08:06 AM
Big Bob's Avatar
Default RE: 77 911 with 3.2 engine not starting
First thing to check Ken in view of the fault description, is that you have good earth between the chassis and the engine. Check the earth strap at both ends and ensure there is no paint or corrosion thats impeding the earth. Reassemble with a bit of grease and star washers to ensure there is a good bite between the strap and the chassis and the engine and the strap.
Regards Big Bob
Old Jul 6, 2008 | 08:22 AM
kotoole's Avatar
Cheers bob
I checked the cabling and it seems to be ok everything else in the car works fine lights etc
Might have to arrange to get it sent to doc
Ken
Old Jul 6, 2008 | 08:38 AM
Big Bob's Avatar
Might be worth running a resistance check on the starter motor, or pull it out and make sure it spins up under 12v. Regards Big Bob
Old Jul 6, 2008 | 11:56 PM
DemonZ's Avatar
If it was a single click, then it's a solenoid problem. Give it a little tap with a hammer, then try it again. If the car starts after that, then the solenoid definately needs to be replaced, and soon.
If it was multiple clicks, then it's a Battery or ground(earth) problem.
war
May 5, 2009 12:23 PM
stretchx13
Jun 14, 2007 10:42 PM
brandnewday
Mar 9, 2005 12:34 AM
cancerofhumanity
Feb 23, 2005 08:12 PM
Mind
Dec 7, 2004 06:57 AM
