Dual Battery System in Cayenee, More Info
Old Jun 6, 2007 | 05:40 PM
Miracle's Avatar
Default Dual Battery System in Cayenee, More Info
Hi Porsche Doc and everyone,
I just found my Cayenne has 2 batteries. I guess the back one is for starting
and other for general use. Does anyone have more info? Having 2 batteries
double the time or capacity to discharge for use or if one is away from their
car? Both battery are quite heavy duty. Anyway to know if a battery has
gone bad?
So far, the lights are bright when I open the doors However there was a
few months I was away, thus now I have it on a trickle charge. Also, if I
need to replace the battery Odyssey batteries have a longer staying power
than Porshce OEM battery. Thank you for your help and detailed description.
All the best,
Miracle
Old Jun 7, 2007 | 07:20 AM
Default RE: Dual Battery System in Cayenee, More Info
Absolutely do not put a porsche OEM battery back in. They are junk. Get an optima, or any quality battery from your local parts store. Interstate, walmart, autostart, etc
[align=right] [/align]
Old Jun 7, 2007 | 10:12 AM
Miracle's Avatar
Thank you Porsche Doc and everyone for your message.
Based on my research Odyssey, Optima, Diehard are the best batteries.
Does anyone know who makes Porsche OEM batteries? Everyone I run
into states they do not if anyone who needs to changea battery yet, I assume
this because most Cayenne are driven are regular basis vs. 911 which some
only drive when the weather is favorable.
Old Jun 14, 2007 | 10:27 AM
Miracle's Avatar
Hello everyone,
Any issues placing a AGM battery like Optima/Odysessy as a stater battery,
and regular wet acid battery for general use in a dual battery system Cayenne?
In everyday use, will one battery overcharge or undercharge? Thank you!
Old Jun 19, 2007 | 12:56 PM
Miracle's Avatar
Default Combination of Wet and AGM Battery, Is That Okay?
Hello,
Any issues when having a regular (wet) battery and AGM (Optima, Hawker) for
Cayenne that uses 2 batteries?? Thank you in advance.
vtsaaber
Jun 2, 2009 01:07 PM
kburgo
Jun 1, 2008 12:54 AM
wyldbill
May 9, 2007 02:01 PM
todds
Mar 23, 2006 06:11 AM
IaMtHeRuThLeSs1
Nov 21, 2004 11:55 PM
