hi again have another problem
Old Feb 14, 2008 | 10:30 AM
ryan 944's Avatar
Default hi again have another problem
the only thing i can say is my clutch is stuck to the floor does anybody know the solution?
Old Feb 14, 2008 | 11:37 AM
Default RE: hi again have another problem
Well, most likely you have a bad hydraulic system. I would replace the clutch master cylinder, clutch slave cylinder, and the hose the runs between the two. You can look and see if any one of those is obvious as the failure point (leaking fluid) and replace just that piece, but typically when 1 goes, the others aren't far behind.
Old Feb 14, 2008 | 01:09 PM
ryan 944's Avatar
yeah thats what i thought it was. so it could just be a leak in the lines?
Old Feb 15, 2008 | 07:03 AM
It could be the metal/rubber line connecting the two, but if that isn't it, then it is one of the cylinders. Bite the bullet and replace it all.
Old Apr 6, 2008 | 04:26 PM
stevepaternoster's Avatar
Is there a cotter pin connecting the two, am less familiar with the 944, but it happened on my 1980 911SC and all it turned out to be was a bad pin in the pedal assembly....easy fix.
Steve
Old Apr 25, 2008 | 12:16 AM
tdoggindahouse's Avatar
Clutch cable adjustment? Does seem a little severe for this though.
q5ka
Jun 4, 2007 07:53 PM
TheDarkPlatypus
Nov 5, 2005 07:02 PM
Trader4Less
Apr 15, 2005 06:59 PM
Trader4Less
IaMtHeRuThLeSs1
Oct 22, 2004 04:24 PM
