944 s2 will not go into gear
Old Oct 28, 2008 | 08:29 AM
riker's Avatar
Default 944 s2 will not go into gear
last night i was driving my 90 944s2, i went around a corner and as i shifted into 5th i lost all power to my back wheels. the shifter felt like it was going into gear as usual, but when i reved engine it wouldent move at all. none of the gears are engauging (<-sp?). i drove the car aprox. 700 miles over the weekend and there were no problems at all. to me it sounds like a linkage of some kind. (dont have much drive train expierience on either of my 944s) ideas?
Old Oct 28, 2008 | 10:56 PM
Default RE: 944 s2 will not go into gear
My guess is you had a CV axle come loose (bolts either broke, or backed out).
Old Oct 28, 2008 | 11:22 PM
riker's Avatar
its an LSD trans. any other thoughts
i appreacheate it though.
Old Oct 29, 2008 | 03:34 PM
If the gear shifter feels like it is going into the different gears fine, then the clutch should be ok. I would next check the torque tube to transaxle input shaft coupler and make sure it is still ok. No grinding noises at all?
Old Oct 29, 2008 | 09:34 PM
riker's Avatar
i checked the car out some more today on my lunch and i put it in all the gears and pushed to feel if in was in gear. when i pushed it, it felt the same in all the gears (with the car off). im getting it towed tomorow, im thinking maybe a linkage of some kind? no grinding sounds thankfully.
Old Aug 29, 2009 | 04:33 PM
84'944's Avatar
I am having the same problem in an 84. can anyone help me??
hairless ape
Jun 10, 2010 01:01 PM
leonardo
Jun 16, 2009 09:55 AM
James944
Jan 24, 2008 04:54 PM
cdlaser54
Aug 8, 2005 09:21 PM
EuroKing666
Jul 17, 2005 01:14 AM
