bad fuel smell porche 944
Old Nov 15, 2005 | 08:20 AM
jimmy_de_vid's Avatar
Default bad fuel smell porche 944
i have a bad fuel smell at the front of the car there are no signs of a fuel leak.my car is a 944 non turbo
the car runs o.k.but at times it sounds a little chokey similar to the carb being flooded but it does not appear to be flooded.
any help would be appreciated.jim.
Old Nov 15, 2005 | 10:22 AM
Default RE: bad fuel smell porche 944
If you are smelling fuel, you probably have a line weeping somwhere, or an injector seal leaking. Sometimes you need good light with the car running to see the leak. Could be an injector seal, a small pinhole crack in the fuel rail, or 3 of the fuel lines. I would check everything very very carefully.
Old Nov 15, 2005 | 11:39 AM
thankyou i will try what you suggest i will keep you posted. Jim
whiplash_s
Jan 27, 2008 10:44 AM
PorschePilot
Jun 16, 2007 11:24 AM
Schnucki_944_cab
Jul 15, 2006 12:13 AM
guardsred944
Oct 28, 2005 10:46 AM
guardsred944
Oct 28, 2005 02:32 AM
