Help!! Boot wont open. 84' 944
Old Jan 30, 2006 | 06:12 PM
mutley666's Avatar
Default Help!! Boot wont open. 84' 944
The boot wont open!!
When I press the switch in the drivers footwell I can hear the solonoid trying to open the boot, But it wont budge. Also I cant turn the key far enough round and I dont want to snap the key.
Any ideas,
Is there a catch at both sides of the boot as I can see a rod going to each end.
Old Jan 30, 2006 | 07:59 PM
AHJax's Avatar
Default RE: Help!! Boot wont open. 84' 944
I am guessing by Boot you mean trunk :-) I have the same problem with mine, I have to gently "pull" the deck a little to either side while lifting the lid.
Old Jan 30, 2006 | 08:24 PM
One of the pin locks on either side is probably worn out and sticking. I give mine a nice nudge with my knee to open it, lol. They get pretty rusty over time and start to not work.
Old Jan 31, 2006 | 09:31 AM
CTiggerPigglet's Avatar
I had a simular problem with mine not to long ago. The hatch doesn't open great at the best of times, but I (the same as you) couldn't open it with the key or the switch. As you say you can hear the motors going, but the boot still won't open.[:@]
I found that the rod from the motor had parted company with the lock at the lock end.
To fix it, I climbed in to the boot from inside, reconnected the bar, then (at the same time) got someone to open it with the key. Now, with the hatch open (and a lot more room to manouvre) you can replace the missing spring-clip on to the end of the rod.
I hope this helps, if not...I'm stumped!
845mx5
Jun 9, 2011 08:49 AM
D Butler
Jan 15, 2009 02:33 PM
my911
Apr 8, 2008 07:25 PM
ducati4882
Feb 27, 2007 04:48 PM
GodlyPolak
Sep 5, 2006 06:30 PM
