Help please - Topping up manual transmission fluid -on '86
Old May 30, 2009 | 10:14 AM
dave1986944's Avatar
Default Help please - Topping up manual transmission fluid -on '86
First time getting at this..I see the drain plugs, is the fill plug the rubber plug on drivers side toward front of transmission? any reco's on gear oil to use? Thanks very much.
Old May 30, 2009 | 04:49 PM
There is only 1 drain plug (the lower one). The upper one is the fill plug. 17mm allen. Takes between 2-3 quarts.
Old May 30, 2009 | 08:02 PM
thanks very much - so apparently both th fill and drain plugs are 17MM aluminum plugs. Maybe the hole with rubber plug is some type inspection or tool access port?
Old May 31, 2009 | 02:35 PM
Well they should be steel plugs. The rubber plugs cover the access holes to the torque tube coupler which needs to be disconnected when removing the transaxle.
Old May 31, 2009 | 09:27 PM
Default Great.
Got it - thanks very much!
Filarabit
Jun 12, 2012 09:24 PM
SXN
May 23, 2008 11:33 AM
Liftereyes
Mar 22, 2008 09:56 PM
TheDarkPlatypus
Aug 20, 2005 07:21 PM
