power steering
Old Oct 23, 2006 | 12:50 PM
kenburkeen's Avatar
Default power steering
Am I correct in assuming an 89 porsche 944 takes atf for power steering fluid like the 87?
Old Oct 23, 2006 | 01:27 PM
Default RE: power steering
Correct, ATF Dextron III
Old Oct 23, 2006 | 03:46 PM
kenburkeen's Avatar
whats the easiest way to drain the system so I can refill it? I looked on the 944 FAQ and did not find anything
Old Oct 23, 2006 | 10:27 PM
Undo a could of hoses at the rack, and the pump and let it gravity drain. Then fill everything up and work the air out. You can do it a couple times if you want to get everything flushed good.
maggot
Aug 12, 2006 08:36 AM
M3944GTIslave
Jan 30, 2006 10:14 PM
garvey
Jan 9, 2006 10:45 PM
Zechs
Aug 21, 2005 10:50 PM
6vaughts
Feb 7, 2005 12:10 AM
