Vibrating noise above transmission.
Old Oct 7, 2004 | 06:55 PM
vmorris272's Avatar
Default Vibrating noise above transmission.
Hi everyone!
I have a later model 85/944. It has a vibrating noise above the transmission when I downshift through the gears coming to a stop. The car runs and shift's fine.I cheecked the exhaust system and the heatshields over them to see if they were lose .But know problem found.It seems to be coming from the shift cable or shiftcable tube.Has enyoneout there ever herd of this tye of problem before ?If so what is it and how do I fix it.Any help you all could give me would be fantastic.
Thank you all
vmorris272
Old Jan 19, 2005 | 02:01 PM
Me944's Avatar
Default RE: Vibrating noise above transmission.
My bet would be the motor mounts. A vibration can and will travel quite well in a 944. Also try to isolate where the vibration is from. Does it happen when the car is in gear? out of gear? clutch in or out?
Old Jan 19, 2005 | 02:16 PM
sh944's Avatar
You have a vibrating noise, not a vibration itself, right? Its probably the heat sheild that mounts above the torque tube in the "hump" that is contacting the shifter rod tube. If you can get the car up on a lift, it should be pretty easy to find and fix.
Regards,
Old Jan 19, 2005 | 02:27 PM
sh944's Avatar
It might also be the heat shield by the muffler, now that I think about it...
Regards,
rope
Oct 13, 2010 08:24 AM
pockets
Mar 6, 2008 01:26 PM
Allen
Jan 11, 2005 03:42 AM
Allen
Jan 11, 2005 03:37 AM
vmorris272
Oct 5, 2004 09:37 PM
