Water temp ?
Old May 23, 2008 | 09:53 AM
McIntyre's Avatar
Default Water temp ?
I'm noticing that my h2o gauge seems to be moving erratically, it moves around within the correct range but i'm becoming nervous about the possibility of overheating.Fan is kicking in , but it will run at the 3rd bar then all of a sudden it will drop back to center, then return to the 3rd bar then back again.Is this a thermo problem? or is it a sign of electrical malfunction?
Thanks...Mc.
Old May 23, 2008 | 10:38 AM
Default RE: Water temp ?
Well, it will vary while you drive. Since it is going up to the 3rd line, I am guessing you should probably put in the cooler auxillary fan switch. My car runs at the first white mark while driving. If sitting at a stop light in warmer weather, the temp mark will go to the 9 oclock position, the fans will kick on, then it will drop back to the first mark. This is normal operation.
If the gauge on the other hand is bouncey, then replace the temp sensor and clean your grounds.
Old May 23, 2008 | 01:12 PM
McIntyre's Avatar
Hi Doc, yes the gauge is bouncy(it has not done this before now).Looks like i'm tracking down temp sensors this weekend...lol.Modified fan switch?...huh?..Will it engage the fans at a lower temp?This would be great, can I order this part from local import auto store or is it a dealer-only item?
Your help is much appreciated...Mc.
Old May 25, 2008 | 09:08 AM
willard3's Avatar
Look here, there are 3 different temp fan switches; scroll to middle of page....
http://www.paragon-products.com/SearchResults.asp
[align=left] [/align]
Old May 25, 2008 | 09:16 AM
Big Bob's Avatar
Can I also suggest a coolant drain down and a flush out with clean water. Ie Bottom hose off and flush from filler tank. Then refill with Clean Water and Summer Coolant or Antifreeze.
Regards Big Bob
Old May 27, 2008 | 02:53 PM
McIntyre's Avatar
Thanks guy's. your suggestions are well received.Had to work out of town(big tile-job)this holiday weekend but will tackle this soon.
Again, thanks!.Mc.
olmanfr
Sep 13, 2007 08:43 AM
jurassicjaf
Sep 9, 2007 09:05 PM
kabir0210
Apr 22, 2007 08:08 PM
crimson96
Feb 13, 2006 07:34 PM
AHJax
Oct 25, 2005 12:35 PM
