Newbie Questions........ Please Help
Old May 7, 2008 | 04:45 PM
  #11
Big Bob's Avatar
Default RE: Newbie Questions........ Please Help
Got to stop playing now. Mrs Big Bob is giving me a hard time about not spending time with her! Bye BB
Old May 7, 2008 | 04:46 PM
  #12
cmilam's Avatar
We won't tell the Mrs about the babes
Old May 7, 2008 | 07:30 PM
  #13
The brakes will clean themselves up as you drive, the rust isn't an issue. Just take it easy and go out somewhere that you can drive around dragging the brakes slightly, do some mild the moderate then hard braking if the brakes feel good and are stopping like they should. A good run around town, and you should have shiney rotors again
Old May 8, 2008 | 02:49 AM
  #14
Big Bob's Avatar
ORIGINAL: cmilam
Thanks guys or she will take away my Porsche Keys! (And half the house etc!!!)
Big Bob
Old Jun 28, 2008 | 08:33 PM
  #15
Freddy's Avatar
I want to thank everyone for the good tips also. I just purchased a '85 944 that has been sitting a long long time.
One question: If I crank it by hand and that action itself breaks the timing belt, do you think I can hurt things? Or... just go easy & if it stops turning, STOP TURNING!
Old Jun 29, 2008 | 02:16 AM
  #16
Big Bob's Avatar
If your intent is literally to turn it by hand via a wrench and socket on the crank, that would not be a significant risk if the engine moves reasonably easily when you start to turn it.
If the engine seems siezed when you apply the torque, then you might want to do some lubtication of the bores etc through the plug holes and leaveit to soak before attempting another turn.
The Porsche Docs recommendation is that if the engine has been standing for a long while then a new belt is mandatory.
So get the engine turning by hand is one thing, but to try and run it up on the starter motor that is a definite no no until the belt has been changed.
Big Bob
Old Jun 29, 2008 | 04:19 AM
  #17
Freddy's Avatar
Alrighty. I'll add some cylinder lube... Marvel Mystery oil is my weapon of choice unless someone thinks of a better one.... let it sit a day or three & give it a try.
Thank you!
Simonerlton
Feb 16, 2011 10:58 AM
BayArea
Nov 2, 2007 05:18 PM
kurtposer
Apr 16, 2007 06:10 PM
hollywood_ikr
Feb 13, 2007 04:42 PM
hmmhoyhoy
Jan 6, 2006 09:53 PM
