WARNING LIGHT QUESTION
Old May 23, 2008 | 09:46 AM
McIntyre's Avatar
Default WARNING LIGHT QUESTION
Ok, I have an 84 944 that came with a 83 owners manual(was built in sept 83).The question is, on the center dash console i have the typical layout of gauges and warning lights but i'm unable to identify one of the warning lights in a 3-light cluster thats on the right side opposite of the fog-light.It's a circle with 3 dash's on either side of circle.This light came on breifly the other day but has since turned off.My manual does not list this warning light and I want to make sure i'm not disregaurding something critical.
Thanks alot...Mc.
Old May 25, 2008 | 06:34 PM
mskldrmn's Avatar
Default RE: WARNING LIGHT QUESTION
I believe that this is the brake pad sensor warning light. Changing pads should do the trick. But be careful when doing it, I have an 84 too and when the old pads came out, the sensor popped off the wire and it was a pain in the rear getting them to stay back in place. The lights didn't go off immediatley after changed but a few days and no more lights
Old May 26, 2008 | 09:40 AM
Yup, brake pad sensor. You need to replace the sensors when you do the pads as well. The other trick is to just cut the sensors off an inch past the connector to the main harness and solder the wires together to kill the light (You still need to put in new pads).
kabir0210
Apr 22, 2007 08:08 PM
porschenein59
Oct 8, 2006 01:19 AM
spooey
Jul 19, 2006 04:43 PM
mani
Jan 26, 2006 01:30 PM
Darvious
Aug 10, 2005 03:20 PM
