Need advice on supension
Old Dec 14, 2008 | 02:40 PM
mike48's Avatar
Default Need advice on supension
I probably should have posted here in the first place, but I was a newbie and decided to intorduce myself there. Anyway I have a 1980 911SC which sags at the right rear bumper about 3/4". I tried adusting the front height adustment to affect a diagonal correction which did not work andcouldn't get to the rear soI ordered a wrench to tackle the 36mm ecentric. Before I go to the trouble and expense of tackling the torsion bars, I wanted to see what advice others might have about converting to some other form of adjustable rear suspension, either coil overs or ?.
Newbie and still having fun. Thanks,
Mike48
Old Dec 14, 2008 | 03:19 PM
pete917's Avatar
Default RE: Need advice on supension
I am doing a coilover conversion as we speak (or type).....
Im doing a RSR Coilover spec. Its almost finished so should be able to tell more soon.
I also added an RSR spring plat to the back to make toe easier and independent of camber.
Old Dec 14, 2008 | 04:47 PM
mike48's Avatar
pete917
what brand did you use?
mike48
Old Dec 14, 2008 | 04:49 PM
pete917's Avatar
hi Mike
I went with the original bilstein with RSR valving and springs. I made one slight change and included helper springs all round.
They are on the car but Im not quite finished, so cant tell yuo about ride quality or geometry settings etc. But Im nearly there (circa a week)
Pete
JohnE1000
Mar 25, 2008 11:37 PM
j1az
May 17, 2005 11:10 PM
htown84
Jan 23, 2005 10:11 PM
snoel
Dec 24, 2004 09:18 PM
snoel
Apr 27, 2004 11:35 PM
